Summary
The intermodal USAT cars with shared trucks on 10 foot diameter curves with extra weight to prevent string lining result in the bottom of the wheels rubbing up against the underside of the cars. The photos show how the wheels have worn away the plastic on these parts.
Details
My railroad has predominately 10 foot diameter curves. I have 3 sets of the 5 intermodal shared truck sets of cars. I had to add weight to them as they would string line in certain parts of the railroad when trying to pull all 3 sets. They have proven to be the most difficult to work with on my railroad. This is understandable due to my sharper curves and steeper grades.
I had a run recently and had trouble yet again with these cars and SD70’s pulling them.
I contemplated switching to KD couplers but due
- Tight radius of curves I would have to do truck mounted
- I didn’t realize how much higher the couplers would need to sit. I would have to do offset and the while USAT couplers will couple with KD couplers, the heights would be off.
One of the things I noticed about my intermodals is a squealing noise they would make from time to time. This past weekend when I realized at times the wheels are rubbing up against the cars themselves. This is amplified when extra weight is added to the cars and the cars are being pulled up a steep (up to 3%) grade on curves.
The photos show how the bottom has been worn out.
I have a few solutions in mind
- Remove that part from the cars. They come off easily, and can be put back easily if I want to. This removes detail from the cars though. I also realized the wheels could still hit the other part of the car. Since the material has never worn off there perhaps not, but with that piece gone the wheels might actually slide into the vertical space left behind.
- Add a small washer to each truck to raise up the cars. While it would be less prototypical to do this, my railroad is not exactly prototypical with its sharp curves.
- File away a clearance in the problem areas so the wheels don’t rub up against the cars.
I am betting that once I solve this issue, those cars will work better going up and down sections of my railroad.
Thoughts?
