I was considering the possibility of building a small version of the Norfolk Southern Office Car Special (OCS). When a REALLY good deal came along that possibility turned into certainty when I was notified that the engines were onhand, before I’d even really committed to the idea. Plans right now are for an A&B engine-set and three or four cars at most.
Shawmut Car Shops got me a really good deal on the set and, once the modifications to accurately represent the OCS units, Shawmut will be contracted to paint them up in the Southern Tuxedo paint scheme, as modified for Norfolk Southern.
Aside from some ditchlights, this will be my last railroad purchase for a while, so I wanted to show them off before they meet the “cutters’ torches”.
I have a lot of stuff going on here right now, so I doubt I will get into the work needed any time soon, but if you guys want, I’ll make sure i take pictures to show here. Let me know.
As for the things needed, they are as follows:
“A” Unit - NS 4271 (NS Class F-9A):
Ditchlight “compartments” cut into the nose and the ditchlight castings installed.
Twin sealed beam headlights replacing the single nose light.
“Plating over” of the front door and smoothing the nose to eliminate the door hatch.
Addition of Electronically Controlled Pneumatic (ECP) braking cables on the nose.
Addition of Locomotive Speed Limiter (LSL) lights.
Multiple Unit Socket & hoses.
HEP sockets.
Locomotive ‘jumping’ socket.
Several extra grabirons on teh nose and roof.
Complete rebuild the fuel tank area.
Replacement of twin single chime horns with NS current model.
Addition of modern “stapler/Sinclair” radio antennae.
Reconstruction of steam generator area to include new HEP-engine mufflers and Geep-style external fan.
Elimination of “pointed” roof at rear to be flat with carbody.
Addition of modern twin-bulb headlight on rear of unit.
“B” Unit - NS 4275 (NS Class F-7B):
->(I don’t have any detailed shots of the B units yet, so more details may end up being needed, but this is the list SO FAR)
Rebuild of the fuel tank area.
GPS/LEADER box on roof.
HEP cables pass-through.
One other thing to look at is to see if I can convert the USA truck sideframes to represent conversion to modern roller-bearings.
Since I’m planning on these being a set, I hope to get a carrying case for the units together, allowing for them to be permanently coupled. I am also considering, but not absolutely sold, on the idea of converting the trucks to Aristo’s RS3/FA1/U25 trucks in order to get the ball-bearing-supports of the primemovers. Depending on USA reliability, this may go by the wayside. I’m planning on a single sound card with one speaker for each unit. I’m not certain which RC controller I want to go with yet, but I am thinking of possibly making the “B” unit non powered to save battery, but I haven’t thought that far ahead honestly.
Any thoughts to offer?
-J.D.
