Thanks again , I learned early on that with lipos you land and measure cell voltage , a lot , untill you learned the safe amount of time to fly , and retain a safety amount of time as well .
So in my use of the lipos , I will not be leaving them in place , I have other uses for the batterys , just as I currently use lipos in a HLW Interurban combine , baggage door is great for swapping out the battery .
And if I modify the NW2 , it also will have the batteries removed from the fuel tank , fuel tank is a easy on and off .
The NW2 fuel tank will accept something 2 1/4 " , 2 3/4 " , 1 " , easy .
The onboard battery with rc is a nice addition here if need be , I operate track power , overhead catenary power , and with the batt / rc , this gives me 3 powered units on the same track with out dcc or such .[ I do have DCC Digitrax with my HO trains ] but not outside , yet .
And I use my rc plane / helicopter lipo batteries and with the 2.4 ghz transmitters , to also operate my trains .
Oh yes , last year I 'landed" a plane in the top of a really tall tree , many hours later , my son got it down with no damage , to the plane , but , with the lipo being on all the time while in the tree , I had a SWOLLEN 3 cell lipo , yep , it was bad , and voltage was like 5 volts for a 3 cell , 9 volts being the low limit cut off for 3 cells .
Lipos are things that need care in use , but they are usefull .
