I recently acquired a USA NW-2 for a project for my dad’s railroad. One part of that project required replacing the stock wheels with Northwest Short Line replacement wheels. Wouldn’t you know–once I opened up the motor blocks, I discovered that 7 of the 8 axle hubs on the gears had cracked, and the axles could spin very easily. This is a known issue with USA gears, though for whatever reason doesn’t seem to get the publicity as gear issues from other manufacturers. Be that as it may, the fix for this is pretty simple. All you have to do is put some sort of clamp around the hub, and voila!
Question is, what to use? A while back, I read about wrapping fishing line tightly around the hub and gluing that in place. Later, I read of using 10mm OD brass tubing. Well, I had neither on hand, and being a rather impatient sort, I went looking for alternatives.
Then it hit me.
Literally.
I was swinging my desk lamp around and one of the springs popped off. I looked at the spring, and I looked at the gear. I measured the spring. I measured the gear. The inside diameter of the spring was just slightly smaller than the outside diameter of the hub on the gear. I could twist the spring on the hub, and the spring tension would compress and hold the hub together.
I put the spring in place, then cut it off with a cut-off bit. I can’t say for certain, but I think the heat generated from cutting the spring off while on the gear may have melted the plastic on the gear just a bit to help hold the spring in place. Dunno, but it’s sure not going anywhere.
The new axles pressed into the gears without any issue, and are very, very snug!
I put everything back together, and it’s very sturdy.
