So for the MIK challenge I donated a set of metal trucks. This is the second version of my foray into casting metal trucks. The idea is an early wooden arch bar. My first design had cast in bolt heads and cast in springs. I did not like them at all. The detail just wasn’t there. So I remade half the mold with eliminated the springs. Now I still have the molded bolt heads but I just filed them all off when cleaning up the flash. In their place I uses on top 00-9 brass bolts and on the bottom 11mm wire threaded and then screwed on a 00-9 brass nut. I then drilled a hole and glued them in. The picture doesn’t show the bottoms but the detail looks much better. Also I used a fish hook to get the eyebolts for chaining the trucks to the car. The springs are just coild wire and then glued in. I like the design much better. Still not perfect but I think it will be a great truck for the bulk of my fleet. with metal wheels the set weighs in at a pound. They are cast pewter.
