Ric Golding said:Let me tell you a story:
Boy, talk about restarting a conversation from the past. ;-) Still valid thoughts.
It happened one day maybe 5 years ago: I was selling a new LGB starter set I had extra to a nice lady & I had it set up on the living room floor for her. I had always dismissed those couplers. I come from a long background of being a scale freak… but this time there they were and I had to use 'em tonight.
I was surprised by how well they coupled, even on those tight curves, how well they held, how easiy they were to uncouple, how easy they were to uncouple, and how they were no problem in backing up, and especially, how readily the nice lady ‘got’ how they worked.
This experience was an eye-opener. Then the grandkids came along, and visiting novice operators… and I remembered, and made the switch.
After that I played with some 00 - 4mm on 16.5mm -English gear equipped with tension-lock couplers. That’s hook and loop with an additional backwards barb on the hook to prevent accidental parting of the train over uncoupling ramps.
These Brit couplers have been highly refined, a little at a time, over the past 50-odd years. They are gravity-powered, which is better than the LGB spring powered upward motion, they work amazingly with their uncoupling ramps.
They tilt up to the right when seen from the car end. The tilt is one of several very clever innovations: it causes the couplers to contact one another at one point only, in a cross formation. They don’t slip over or under each other, and they can be pushed very easily based on that single contact point. These couplers can be delayed too.
It got better when Max Sarazen from Cape Cod showed me how easily I can delay my large scale hook and loops.
You’re right, Ric, this topic is an old chestnut, isn’t it? There’s always something new to add to the conversation. In my case I never would have thought that I’d find myself preferrng hook & loops!!! Thanks to this conversation, I’m going to scope out those Precision Scale couplers that William mentioned. I’m pretty sure I’ve seen 'em long before now, but I like to keep up!
Meanwhile, William, I see that was your first post here at LSC. WELCOME !!!
