I have been working on patterns for two different caboose models for a few years now. Actually, I started and almost finished them a few years ago, then put them away. I took them out again two weeks ago and finished the bigger of the two. Now I am working on the small one.
The first is a model that is based on the Quincy & Torch Lake #04. It was a coach/caboose. Mine uses the Bachmann closed trolley body as a basis. All of the parts needed are mostly cast in resin with a few being styrene and wire. I even cast the draft gear sills for either kadee or link and pin if so desired. This is a cupola type caboose.
The second is a little 4-wheel model that is as close as I could get it to the prototype; Ferrocarril Mineral De Chihuahua. The caboose still exists today on display in a park. This one is all resin castings with a couple of pieces of wood and wire.
Both cabeese are interesting models, but I don’t know if there would be any interest in these as kits for large scale. Is there any???
Tom
