Pete Lassen said:
looking at turnouts for my RR and I am trying to figure out how to compare brands when the all use different designations. looking at 332 brass, USA has a #6 which looks like a very large, easy diverging route turnout. LGB has a R8, Piko has a R5, Aristo has A #6 and a x wide and AML has a 8ft radius . Which are best size to use, trying to stay over 10’ diameter on all curves if that helps. I am not wanting brand comparisons, I have been told go as big as possible to make switching tracks easy, just what designation to look for that the different brands have
Above are prototype numbered switches. Model switches with an R designation are based on a circle of track.
Although there is an easement curve between the two tangents the numbered switch is made of straight tracks.
There is little rhyme or reason with radius in inches on track made to mm. They are approximations… and each manufacturer has their own system.
Numbered switches mean; a #4; 1 unit of divergence in 4 units traveled. A number 6 takes 6 units of travel before 1 unit of divergence is reached.
Sectional/toy switches have a tangent and a curve so that circle layouts can be made. A Numbered switch won’t make a smooth circle.
What you use depends on the style of your layout. Sectional track or flex?
John
