The build challenge is over and I still have the itch to construct. Since I built the 2 bay engine house I thought how nice woudl it be to have a turntable. Due to space restrictions the turn table will need to be at the opposite end of my raised bench but that is OK.
Here is my inspiration a through bridge turn table that used to stand in Hyannis. I think the photo is from the 60’s.
I like the through bridge design since the pit doesn’t need to be as deep as a conventional turntable. I have already done some napkin sketches to get my mind reved up for this. I plan on building the bridge part using plastic wood. It will be 6" wide by 24" long. I plan on making a square base probably 25-26" square and building up from there. I will need to carve out a corner on my bench and this will hang off the edge. I am also track powered so I was thinking about using a headphone jack as a powered pivot.
If you guys have any tips and tricks so I can avoid “pitfalls” pun intended that would be great.
Thanks
