So I have a couple weeks and then host out clubs meeting. So working to get the layout functional. I have had a problem area since day one. Its a switch combo with two opposite facing left hand #4 turnouts. A first solution to this problem was to buy two hand laid #4s from Bob. That worked okay but I have always had issues with the spikes lifting and the whole thing becoming loosy goosy. So this year I ripped both turnouts up and I am making all new turnouts using the parts.
This is a giant experiment. This is located on my bench section of the layout. All the track in that section is laid on a subgrade of 3/4 PVC lumber on the bench structure. So for this rehab I am using 3/4 pvc as a base, ripped ties from PVC. The spikes i have a long. They go all the way through the ties and stick out the bottom. So I figured why not build the entire thing right on the subgrade. So the track, ties, and road bed are all attached.
When done the plan is to cut out all the old subgrade and and in this new modular unit. Stay tuned. Could be a success or an epic fail.
No I just used the textured side of the PVC board. If you look close especially between the two turnouts some of the ties are far less textured and look almost smooth. Turns out that not all PVC lumber has as much texture or depth of texture as others. These ties were cut from two different scraps. And they definitely do not look the same.
