My goal this summer was to complete the inside loop of track on my layout. I started laying down the left over lattice from my original layout last summer to give the inside loop a good base even though the track will float on top of the lattice. After a close survey I realized that I needed to construct 1 tunnel and a cut-though before I could continue with the rest of the track laying.
I dugout the area for the tunnel and the cut, made a couple new pieces of lattice roadbed, and installed the lattice. The first picture showes the tunnel area ready for the tunnel sides and track.
The second picture shows the lattice exiting the tunnel area (lower right) and continuing through the cut in the center.
The third picture showes the tunnel sides. One is painted and the other one is raw material. These are made out of cedar.
The last picture showes the tunnel sides and the track installed. The track inside the tunnel is attached to the lattice while the rest of the track will float over the top of the lattice. Hopefully I can install the tunnel top this weekend, then cover the entire tunnel with black plastic, and fill in the dirt. I still have to make the portals and the side pieces but that will be later as I have one more tunnel to dig before I can complete the inside loop and start laying track. More pictures to follow.
