Wow that’s a lot more detailed then any “off the shelf” truck I have seen. Very nice.
Stupid question time here. Why cant you print springs out of some kind of plastic? Metal springs look to be too small (scale thickness of the wire wise) and steel being too stiff, maybe some kind of plastic would be soft enough but not too soft when rendered in proper scale.
I’m thinking nylon at that diameter would be too soft. But it might balance out with one steel spring, and the rest nylon. Now to figure out how to draw that in Sketchup…
Burl, I have a lot of springs that are .106 OD x .165 tall .098 when fully compressed. It takes about a pound by the “feel” of them to reach full compression.
If you can use them I’ll hook you up with a bag of 5000 for the cost of shipping.
Randy, the OD would be close enough, but I need 0.1916" tall when fully compressed. Thanks for the offer though.
and why would you want them to fully compress anyway?
So you know the bolster can’t pop out by accident if they’re overloaded.
Nice & amazing!
Question. Why do you really need the springs to be compressed a little? If its just a visual thing, then you could glue the bolster to the side-frames slightly lower then at the top, and then put in your plastic springs. I know my Aristo trucks have actual springs in them, but they don’t seam to compress any, I mean, the bolster appears to me to always be at the top of the opening in the side-frames.
I got my Gary Raymond wheels in this week, as well as some suitable springs. I decided to go with Kadee (IH) 701 springs, cut in half, for the main springs - they’re in the back row, so you can’t see them. Kadee #875 springs were used for the smaller springs in the middle row. That gave enough support to let the whole assembly flex without bottoming out. For the main visible springs, I used my 3d printed springs - which have the diameter correctly scaled.
This is the first set of Gary Raymond wheels I have had, and I am very impressed. I wasn’t expecting the wheel backs to be machined out, but man do they look nice. These would look great on a covered hopper, or a tank car.
Burl,
been admiring your work from a distance and it is fantastic with the resources you are using. I started and got spoiled with the resin 3d printers back in 2006, it is hard to go back, although I recently did have Shapeways do a print on an I beam and it came out great for what I am using it for. One question is that how much will the springs compress in your truck when loaded with a car? being very familiar with the prototype the bolster is pretty close to touching the top of the side frame when there is no car on them, and with a loaded car the bolster would be down only about half the distance shown in your picture. ultimately will affect ride height san coupler position.
Al P.
Good question, Al. Measuring a set of Aristo trucks, I get 25.5mm to the top of the bolster. Mine measure 22mm. I may need to make a slight adjustment there.
