I’m slowly converting over my fleet of equipment from Bachmann, Lionel, USAT, Delron low mounted couplers to a proper body mount (ie when I build or buy a new model it gets Kadees). For those of you who cut off the trip pin on the Kadee’s, what’s the process that you use? Do you remove the trip pin from the coupler completely and than trim, or keep the trip pin on and trim?
Last question, what do you use to trim the pin? Flush cut pliers, dremel?
Craig
The tip is on the underside, I don’t notice it unless the car is wheels up, and I try to avoid that.
