Tried an experiment with a little LGB 50084 transformer (22v/1amp) on a flex track circle that’s a couple of inches under 8’ diameter. I wanted to see how different locos would perform with this little fella on such a tight piece of track.
USA 20 tonner and USA GP-38, both towing a Gunderson, ran without trouble. No surprise. So did an Aristo Dash-9 without the Gunderson. Surprise!
USA SD-40 ran OK at low speed. However, cranking it up to 3 on the transformer’s scale of 4 (same as we did with the first three locos) caused the SD-40 to stall. Surprise!
Changing over from the little LBG to the 20amp Bridgewerks fixed the SD-40’s problem.
As far as the Dash-9 and the SD-40 are concerned, it looks like we’re comparing an F250 with a Corvette. Would you agree?
The way I look at it: the engines with the most efficient motors i.e. lots of power and comparatively little current draw are my favourites.
