Mark Dash said:
Has anyone bought this product and have it laid outside?
I’m wondering if that track could be used to replace all of my brass track. I could sell the brass and get 2x the amount of track I’m thinking. Has anyone that’s battery power tried this yet? Will the rail slip into Aristo/USA/LGB Ties?
3 years ago I bought some of this rail in 5’ lengths, and took it home to Australia in my suitcase. Just bent it in a parabola to fit it in! Once home it straightened out easily by laying it in the sun then reverse-bending it. I use all battery power. This is going to be fantastic, I thought.
I used the plastic rail and nailed it to wooden sleepers. I nailed through the rail foot into the sleeper, so there was no possible movement at each sleeper.
The first section I laid as a test is about 6’ long anda straight siding. It worked pefectly for a year, so I thought I’d try some more.
This time I laid about 10’, screwed down every couple of feet with a curved section of siding. After the first hot day it buckled terribly. The difference between the two ??? - one is always in shade under a tree, the 2nd is in full sun for most of the day.
I then put another length down in full sun and concreted the sleepers in, in a location where I have to walk on the track. Still perfect after 2 years.
So if you plan to use in the sun, you need to really think about expansion. Hold it at one end only let the other end slide. It should be better using slip-on sleepers.
These tracks were all on the level - no grades.
Once the rail has buckled over short lengths (inches) in the sun it cannot be straightened.
I took one 3’ length of straight rail and laid it in the sun - no fixings, just lying there. And it has buckled! Can’t explain that.
I’ve used another 8’ straight length as a siding, mostly in shade and it is fine. This time I didn’t nail through the rail foot, but bent the nails over the foot, as I do for brass rail. It still doesn’t allow much movement as the nail-bending action causes the nail to ‘bite’ into the rail foot a bit, thus restricting it’s movement.
So I’m using up all the plastic rail as guard rails on bridges, check rails on turnouts, fence posts and telegraph poles. To use as guard rails I grind a liitle off the foot of the rail to lower its height. Some will get used when I extend inside.
Unfortunately, I’m not at home, so I can’t provide as pictures.
This is not meant to denigrate Train-Li. Just to share my experience. Axel quite plainly states it’s not for outdoors. And in the right place it is great stuff.
