As it is, I have 5 base and one in-cab TEs.
One of the base units is an early 2-channel, 10 amp unit and the voltage steps are very course and can drift. This was probably the first unit I ever got and is now a “stand-by” piece. The other four (including the failed unit) are the 10 channel units of a couple generations, but one has a bad transmitter in that the membrane is toast. I use three of them to run the railroad.
So, I took the fan, as well as it’s power and antenna cables (that already were cut to length and had the appropriate jacks) from the unit that failed the other day and put them on another unit that functions, but who’s cables were cut shorter by the PO and it had no fan. I wasn’t even sure that it worked until I powered it up, and it linked with the transmitter and adjusted voltage, though the PO said it did.
The failed unit can wait for another TE to fail or a TE donation, and I can take the choke and transistor from that piece when the time comes. (There may be more wrong than just the two pieces.) At that time I’ll also get a hot air solderer, because it would be nice to have anyways. Its a PITA trying to unsolder even 555 chips and get all the pins hot at once. A hot air gun makes this easy.
