OK, I already have one TE receiver recently gone to God. It was working with no problem, stored for two days and then simply failed to accept inputs (power ‘on’ light illuminated but no green ‘code set’ light when transmitter activated). Transmitter checked on another receiver and worked perfectly.
This morning I had a short circuit that blew the inline low amperage blow glass fuse in the track power lead, but the car-type 10 amp fuse did not blow (too slow). Now have constant 18 - 19 volts to the rails with no control. I am ware of reverse polarity issues with multiple receivers, but this was a simple short circuit with only one receiver connected. I fail to see how other manufacturers are able to provide internal short circuit protection (not relying on slow blow external fuses) and yet this manufacturer fails to do so. I am coming to the realisation that the TE is not for me!!! Two receivers now gone to God and two left in reserve.
