I know Tony regularly sets up his R/C conversions to allow the charge jack to be used as an alternate battery input jack to extend run times. Since I’ve had my Shay go dead on me out in the garden several times I’m thinking I should set it up to allow a rescue battery.
When I installed my Run (on)/ (off) Charge switch I used a DPDT type with the batteries connected to the center. In the On direction (Run) the battery is connected to the R/C electronics. In the Off (Charge) position the battery is connected to the charge jack. Configured like this I can’t use the charge jack as an input to the R/C electronics.
I used to be good at this stuff, but I’m getting rusty. I’ve been trying to figure out the wiring diagram but just haven’t hit on it yet. Perhaps that is because the charge jacks I have do not have a reliable built in switch sensing the presence of a plug so it can’t be used as part of the circuit - if that even matters.
Anyone have a circuit diagram made up I can steal?
