I started this - I’ll lead off with the biggest error I have made in laying track.
Simple lesson learned: Plan on WALKING ON THE TRACK in choosing roadbed if you have a combined layout and garden. That’s right, checking sprinklers, trimming, weeding, rechecking for the 10th time an electrical problem, and removal of debris OFF the track that was originally pushed aside. IF the gardening hobby dominates family interest (you may only have the train part) others may be doing the weeding, trimming, etc. at less delicate consideration for the track – translation: They will walk on it.
Simple lesson #2: For track that is ground based, ensure it can be stepped on supported with a solid roadbed. NO, the sand ‘n gravel-based supporting roadbed only settles and after a step or two there are dips. Our 400’ layout and garden is just that- it’s a garden with a train. The track now is on a concrete roadbed – bricks spaced along the track configuration both straight and curved radius and then covered and smoothed out with 1" of concrete. After leveling the concrete, the track sections are then pushed into the cement – the hollow ties will act as a holding source. NOTE: Lift the track after 15 min. so it does not adhere to the concrete.
What’s your biggest lesson?
Wendell
