I’m having a problem with a short somewhere on the track I’ve recently laid. First some background.
We’ve moved to a new location, so I’ve decided to go from track power with a TE to track power & TMCC. I’m using the Lionel base & remote, but I’m using the boards from Train America Studios for my LGB & USA locos. Lionel SC-2’s control my LGB switch machines. I decided on the TAS/TMCC combo after a lot of research into DCC (didn’t like the prices & with the TAS boards I can control coil couplers on any loco or car).
I laid the track from my storage shed out beyond my 1st passing siding & up to the entrance to the main yard. After wiring the turnouts & running power to the track, I tested with an LGB loco. Everything worked fine, with full control of all functions of the TAS board in the loco. So I laid track in the yard until I ran out of ballast (Mount Airy Starter Grit). When I switched on power to test the new track, a fuse blew in the power supply. After checking to make sure I hadn’t left any metal tools laying across the tracks, I replaced the fuse & tried again, with the same result.
I powered off, removed the loco from the track & put an ohmmeter across the rails. It showed approx. 26 ohms! I rechecked all connections & still had 26 ohms. After disconnecting all power leads, the meter was still reading 26ohms! So just for grins, I put one lead on a rail & the other into the ground - you guessed it, except the reading was approx. 128 ohms.
I’ve checked for ground contact with the rails & none is apparent - does anyone have any suggestions for a cure?
Vance
