So with all the talk of switches and what not and trying to explain what was in my head has forced me to get a digital image of the tack plan. Well I finally spit one out on AnyRail. I have limited the grade to no more than 2%, min rail to rail crossover is 10", min diameter curve is 8.5. I have set parallel rail separation at 9" center to center and more like 12" on the curves. Edit: I eliminated a complicated piece of track and am down to 6 switches likely #6 all the way around.
The one siding that starts on the left top and heads to the very right and off the plan is a future spur that may someday run into my front yard. It wont be there initially. Also the two loops are would be designed to be made one at a time. I would build the double crossing and then just add a small sections of track to make sidings until phase two.
My plan is to build this in Llagas creek code 215 aluminum rail and hand lay the switches and crossing. The building is an existing play area that will be revamped into a two story building. The bottom will be the train shed. The top will have a double bunk bed and windows that will allow sleepovers and overhead viewing of the RR. The second story not shown will cantilever over the track by two feet. Stairs are not exact just representative of where they might go. I will make them fit. You will enter the train shed from the opposite side. Min height will be 18" except where it heads of the page for the future spur.
I am thinking since talking to the locals frost heaving is not much of a problem so I am thinking of making raised beds with rock and good draining fill and then trench the road bed in and fill with gravel and then just have a free floating track on that. Walk ways would be shredded bark or decorative gravel.
Ideas, suggestions? This will likely be started next year. Maybe some clearing and grubbing and a rebuild of the play area this year if I get other stuff done first.
