OK,
So now that I have had some experience either running on, or watching others run on, layouts a few times I have a little better understanding of what I can do in my space and what I will enjoy in a layout. So I am rethinking my entire space and my givens and druthers have entirely changed. I am not going to go into all that but I do have some practical application questions. One major decision/realization is this is an old guy hobby. As an active member of my local club I want to be able to have people over to run and they can’t be dodging and climbing over a lot of track. It won’t be fun for them and it will be asking for stuff to get stepped on. So I am really thinking access and that is a challenge in my small space. I am also steering much more towards operations with only one option for continuous running.
#1 how far apart should parallel tracks be on straights? I am going to be running 1:20 NG equipment. I guess the real question is how much clearance between car sides? My hand built stuff will be about as wide or wider than anything commercial so if I build the track so my stuff can pass then so will most anything else. Whats a safe and realistic clearance?
#2 What about parallels on curves? Again NG equipment so not long. No need to bring your extra long car haulers or super long coaches. But I will be running a modified Accucraft J&S coach with two extra windows. This will be about as long as it will get. Lets assume I will have parallel curves where the tightest inside curve will be 8’ diameter. How far do I push out the outer curve to clear the overhangs? Whats a good rule of thumb?
#3 This one more or less I can probably figure on my own but what about clearances to hard structures like fences and the house? These would all be to the outside of any curve. I am thinking 4" to center-line of track would be plenty. I want to maximize my space and push stuff out as far as I can safely get away with. All access will be from inside the layout.
#4 What is a good overhead clearance for tunnels and grade separated crossings? I was thinking 12". Will most everyone’s stuff clear that? I know mine will. What’s the shortest recommended to get most standard stuff under? Again don’t bring your autoracks.
#5 Walkway width. Figuring a mostly elevated layout that has a base height of 0" and max track height of 24" what is the narrowest walkway width that can be comfortably negotiated. I don’t need shoulder room this isn’t a hallway, but is 30" reasonable? Does that allow feet, knees, and hips enough room to clear. Even us “larger” people aren’t that much larger than anyone else until you get to the belt. Again I need to maximize space but also get old gummers through the layout so they can have fun.
Any other logistical issues, or cardinal rules I just can’t break? At this point I am just wonder what reasonable parameters i need to have in place so that it will work and people will be able to move around. Just so we don’t go there, I am setting make curve diameter at 8’, it works and works well so lets not go there. Also max grade will be around the 2% mark with the right to increase it if need be but not by much so lets not go that direction. I have a small space guys so I am not wanting ideals I am wanting minimum practical here.
