As you may already know and not care, I’ve been rebuilding the Iron Island Railroad for quite some time now. Yesterday, I finally reached the point of reassembling all the track ties that I painted many months ago. During all these months in storage, the already weathered brass rails weathered even more. So much more that I needed to clean about an inch of the ends so that the track clamps would have a nice conductive surface to clamp on.
My first thought was to use some Tarn X that I had lying around. I poured about an inch into an old can and stood the rails in it for about 15 minutes. Then, I pulled out the rails, polished them a bit with a rag, and rinsed them. The Tarn X did a great job of returning the AML brass back to its nice yellow, brass color. Well, at least the last inch at each end- the rest of the piece looked awful (or if you prefer, it had a nice, aged patina).
Okay. Well, here’s where the alchemy part comes in. While waiting the 15 minutes for the Tarn X to do it’s thing, I happened across a container of muriatic acid that I normally use to change the pool ph. Naturally, I thought, “I’ve got some time on my hands. Why not try a test piece of track and see if it works any better than the Tarn X?”
I don’t think I would use the word “better.” Maybe, more like… “AMAZING!!!” Or perhaps, “INCREDIBLE!!!” All I did was soak up a small amount of muriatic acid on a paper towel (and yes, I did wear gloves and safety glasses), and wipe down the rail. All the corrosion just came off. No waiting. No rubbing. Instant gratification. Now, the one thing I did notice is that the rail ends that I cleaned with the Tarn X were yellow/brassy colored. The complete 6 foot rail that I cleaned (effortlessly, mind you) with the muriatic acid was definitely copper colored when finished.
So, I have to ask, “Does this resulting copper color mean anything- Good or bad?” Did the muriatic acid etch or alter the brass rail adversely? Will this method of cleaning brass rail adversely affect plated train wheels? Does muriatic acid affect plastic ties (it does come in a plastic bottle)? Any chemists/metalergists out there?
If there are no negative long or short term effects, I think I may have found a better way to routinely clean brass track. Take a pole sander with a sponge or a piece of cloth on the end, lightly moisten it with some muriatic acid (available at Home Depot, pool stores, etc), and walk around the layout. No scrubbing required.
Your thoughts.
-Kevin.
