Not too happy with my results digging a channel and lining it with landscape cloth, and having run out of the bender board I was using to make channels, I noticed a 100 foot roll of 3-inch drainage hose. Well, this method may not work in areas with frost heave, but I found that it was very easy to slit it in half with a box cutter and screw it down to my benchwork to contain soil on the outside and hold ballast on the inside. It takes a natural curved set, and curves gently, much like the track should. It’s working well for the bench area, and will go into regular soil next. I need to poke a few drainage holes so it does not collect water, but I am liking this new method. Thoughts?
