Something I’ve been working on but haven’t posted here. On LSC back in October there was a post about 3d printing software that ended with a discussion about combining different construction methods with 3d printing. Martin Sant mentioned the TP56 which I though was an ideal loco to experiment with.
The hood and cab where printed with an FDM printer but could be done with sheet material and a laser or CNC (my next experiment). Most of the details are printed in resin and pressed into holes and slots. I believe many modern locos can be made with this method.
I chose to cut down an SD40-2 frame as is done by the prototype builder and used a USAT SD40-2 truck. This proved to be a pain in the azz and I should have just printed the frame. (I will if I make another).
There have only been a few of these built and they are all a bit different. I chose to incorporate the features I like best and because the power is provided by a Caterpillar C9 I went with the CAT theme.
For those of you not familiar with this cool little loco http://www.tractivepowercorp.com/
Latest progress:
Cut and tinted glass and added gaskets, Ditch lights, Sunshades, Wire grabs, decals and Safety stripes
I decided to add a honeycomb pattern to the first door to carry the CAT theme.
redesigned coupler mount with integrated
added speaker opening to the fuel tank.
Coleman Mach 8 AC unit - Passable but I need to learn to merge curve surfaces.
todo list
Brake chain
more decals
Handrails and stanchions
Lift bars
Install Railpro
