Well I haven’t finished my rolling stock builds but I just had to start something new today. The MoW crews will need somewhere to store tools etc. and a place to hide from Management. This measures 24’ X about 12’ with 9’ walls. And a 7’ X 7’ door for the handcar. The framing is only for something to glue the clapboards to and provide the look of trimboards at corners and around door/window openings. First the front wall with the siding starting to be installed.
The back wall framed up.
The siding, 1/8" X 7/16".
The Framing pieces, on the left 5/16" square for interior frames and on the right 1/2" square with 3/16" X 3/16" rabbets milled in oposite corners. These are used at corners and door/window openings.
That’s all for now. Edit for siding dimension.
The front wall.
