OK, here is the deal. I have a spot where two tracks enter two tunnels, one of which is directly over the other. This is O scale and the height differential is 24" or so (scale nearly 100 feet.) The upper track approaches the tunnel on a curve on a trestle that runs right up to the nearly vertical face of a rock wall. The lower track approaches its tunnel in a sharper radius curve on the ground.
What I would like to do is take the middle of the trestle out and replace it with a deck bridge, but return it to a couple of trestle bents before it plunges into the tunnel. The lower track can align itself to its tunnel running in under the deck bridge. I would like to design two bents which the lower track can split as it enters its tunnel.
There is really no choice in changing the verticality or the position of the rock wall and both tracks are coming off of lift out sections that are locked into the corner of the room.
What I want is a practical bent design and not a suggestion to throw out the track plan if you please. I searched Google images but my Google-Foo failed me.
Any ideas?
Thanks
Charley
