I just put up the finished photos in the voting thread and thought to put a few here to explain them.
The roof is supposed to be thatched. I thought about using a straw welcome mat but they all had writing on them so I used this material instead which comes from the lining to a hanging plant, it is a coconut material. Under the thatched roof is a thin aluminum real roof that will keep the weather out.
I bought the lambs years ago and they were supposed to be G scale but I think they are more like O. They came in handy for this application. The shamrock I took from a St Patricks day necklace. The signs were printed onto decal paper then applied to a thin styrene and glued to the side of the building. The lanterns were made from a clear ball point pen, 2 brass nails and 2 wingnuts for electrical wires.
I was running out of Taylor blocks so I had to put a door on this side. The barrels are cut from a dowel and a closet pole. On the back roof you can see where the solar light is. I had hoped to rewire it so the electronics and LED would be inside but the unit was pretty tight so I drilled a hole into the roof for the bulb can fit then on the inside glued the tinted difuser.
I’m not a fan of Guinness Beer but they do have a new Lager called Hop House 13 that is pretty good. I am a fan of their advertising posters. Every pub in Ireland has them plastered on the inside and out.
Being an Irish pub I thought it would be neat to add a Celtic cross around the circle window near the peak.
The tall Leprechaun is now the mascot for “The Lamb and Clover” Pub. Stop by on the grand opening day and he might just hand you a gold coin good for one FREE pint !
I used all but 3 of the tiny Taylor stones and actually had to make several out of wood to finish off the back of the chimney.
This was a fun build and as usual you guys have built amazing things.
