After planning and measuring and measuring again I have come up with a plan for the Mik 2021 build challenge. I will be replacing an aging and rotting factory building, that has already been rebuilt once, on my RR with a larger facility. It is ambitious with 2 towers and a connecting corridor above 2 tracks. The required tin can (soup in this case) will be prominent on the smaller portion and used as a fuel tank.
Last Spring I rebuilt my 2 bay engine house, a Mik project where we all used a Taylor door, and I used plastic sheet for siding. The plastic was ripped on my dado blade to make it look like clapboard siding. I’m thinking about doing the same for this factory build but I might not have enough. A 2x4 sheet is $25. I have one plus some bits so this build might use wood siding as well which I have plenty of. There is still more figuring to do on that before the starting gun fires.
Here is my napkin sketch.
