Work has been hectic and the spring weather wet and cold. Despite this I have finally got enough done to have a fully operating point-to-point with train turning capability at both ends…
Indoors my balloon track is fully operational and all the benchwork done. Yards are yet to be built except for a few sidings that aren’t screwed together yet. Outdoors the Wye that has been in place since last fall has finally been wired with three blocks and a reverse section in one tail which is also the end of the main line.
I don’t yet have any industries or sidings. Until some are added, operations will be limited to passenger excursions and photo freights, a kind of out and back operation with trains waiting in the Wye for the main to clear for the return trip - EBT style.
Running a few test trains yesterday, I got to thinking about rules. Should the Wye and Balloon always be operated in the same direction? Should switches have a Normal position that they must be lined to after use?
If running just one train and one operator, it’s quite convenient to run the balloon and Wye in the opposite direction as the last run - you can just leave all the switches lined the way you exited, then the next trip enters from the other direction. I can see where this would get messy fast with multiple trains, or multiple operators - thus I’m thinking there should be rules.
At the Wye end, it’s easy to say that switches should always be left lined for the main. That leaves one switch at the other tail with no clear rule. Should it be lined so that a train backing in from the main does not need to throw the switch before entering the tail (and stopping to reverse)? That seems to make sense to me, but requires a second stop after the train passes through the switch while exiting. But stopping to do stuff is good, Yes???
OK - So let’s talk about Indoors. Direction seems simple. The clockwise route around the balloon give the longest track before the reverse section to allow the train to clear all switches before stopping. Since operation from indoors to outdoors is usually done looking through a window, it is logical that the balloon switch should be left lined to the return route. This requires a departing train to stop as soon as the entire train is on the main. Is that weird, or normal? Either a departing train or an arriving train is going to have to stop at that switch. I think the rule should favor arriving trains for my convenience.
I hope this makes some sense. It’s late and my brain is about toast from work. If not, please excuse the ramblings of a mad man
JR
