Tight curve
Work has finally resumed on the switching layout. I built a trolley on an Eggliner motor block. Has anyone run an Eggliner on a tight curve? How tight?
Doug;
Surely an “Eggliner” will negotiate a two foot radius, at least…you should know…
Fred Mills
Hi Fred. I am going to see if it can handle 2 foot diameter. I was curious if anyone has gone real tight! Maybe I will loosen it up to 30" diameter!
Well, my guess is that the eggliner will at least traverse a 21" diameter circle… based on the fact that Aristo used to sell that circle and I’ve seen an eggliner on one of these.
So, no problem.
