The track cleaner is complete, though I may add a flashing diode at some point in the future to indicate when the cleaning motor is running.
It’s a simple matter to hold down the battery pack with a couple rubber bands. This also allows for a quick change. I got two 11.1V, 2,200 maH, Li-ion packs and a charger for just $30 shipped, but had to change out the plugs to what I had.
From the bottom you can see the workings. The six 1/4 oz lead weights along the front edge counterbalance the battery pack that sits behind center. This is also just the amount of weight necessary to make the abrasive wheels contact the railhead.
A close-up of the switching arrangement. The center-off, DPDT switch selects the battery pack or wheel pick-ups. Note the bridge rectifier connected to the track pick-ups. This ensures that the motor spins the same way as it does on the battery regardless of track polarity. The SPDT switch selects whether the motor spins when the unit is being push or pulled. For example, like the LGB track cleaner, it can be set to spin the cleaning motor when it is being pushed, but the motor will stop when it is towed the other direction. This also allows for the unit to also be towed so that it runs when pulled behind a battery-powered engine, but stops when pushed in reverse.
In theory, the switch/motor direction/combination create an “auto-off” feature. The motor spins so as to pull the car away from the engine regardless of if it is pushed or towed. If the push/tow engine should stop, and the cleaner motor continues to run (as it will with batteries or under track power if the push/pull engine gets stuck), this opens the coupler switch shutting off the motor.
The old springs had lots of wear and not a lot of tension so bottomed out. Luckily, I have plenty of spares from the various AristoCraft engines and coaches. These work fine and all moving and rubbing areas received a coat of LaBelles grease.
And, because it is imperative that the motor be easily removable to change the wheels, I wanted the deck to be quickly/easily removable with a way for the wire to come through, but I didn’t want it to show. A pair of magnets are CA’ed to the bottom of the deck to secure the deck to the two screws that hold the motor in place. The extended battery wires allow the deck plenty of freedom when removing the motor or working on the chassis. The wires are secured in the channels with wedges of foam so that they don’t interfere with the placement of the deck.
