Don Howard said:
I am a little confused as to the advantage of the digital vs analog.
Digital always costs more.
I have an HS-125 that is nearly the same thing, except it does not come with the neat cradle.
It is not installed yet so I have yet to fabricate or figure out a mount for it.
The Hitec HS-7115TH Servo has the SMALLEST spline of all the Hitec splines and has very few arms available.
Servocity call the spline their type A1
Hitec calls it a Feather Horn
Beware in the diagram I linked to below as there are TWO #34s.
In live steam I would want just about anything else but the A1/Feather Horn
http://www.hitecrcd.com/products/accessories/servo-parts-and-accessories/servo-horns-and-hardware.html
Don,
I think the ‘digital’ versions have more electronics inside so they can do things like better centering, or 180 degree operation. Not too valuable for a railroad, though the 180 degrees is nice. [Servocity sells a ‘programmer’ so you can set up the servo yourself - maybe 145 degrees this week?]
I don’t think the A1 horns are a problem. Clearly a thin servo needs a small drive spline, or it won’t be thin. The two arms that come with the servo look adequate for a reversing lever, and I use chain drive on my throttles, so a bush would be needed anyway.
