Hi all,
Far Northern California was/is one of the largest producers of gold ore/bullion in the country and I had the chance to visit one of the oldest, still producing gold mines in this area last week. Attached is a brief history of the Washington Mine and a link to their web site for further information if your interested. Oh, yea, I also included a few pictures. Hope you enjoy the visit.
Rick
The Washington Mine, the first gold quartz mine in Shasta County, California, was discovered in 1852 by John Souter and his partner John Syme. This mine became the first patented mine in California. In short, a patented mine is one that the claimants have filed the correct papers under the amendments of the General Mining Law of 1872 and been granted absolute title to the land that is encompassed by the claim. Of course a number of criteria must be met not the least of which is paying all the required processing fees and purchase price of the land applied for. The Washington Mine lays about 3 miles northwest of French Gulch, California along French Gulch Creek and is currently operating full time. During the initial mining period of the 1850’s 1870’s the Washington produced about 2 million dollars. Following a few idle years the Washington was purchased in 1930 by a dentist living in Shasta City, Ca who leased it to a French Gulch miner, J. H. Scott, for $10,000 and 25 % royalties. Scott took out $800,000 before World War II forced him to close down. The Washington Mine has operated on again off again since the close of World War II and continues to produce gold ore in quantities that keep it in operation. The mine is currently owned by the SHASTA GOLD CORP and is operated by the French Gulch (Nevada) Mining Corp. A link to the Shasta Gold Corporation’s web page is here if you are interested in more information and history of the Washington Mine.
Shasta Gold Corp. » The Washington Mine
Here is the mine opening, tunnel, adit, or what ever you want to call it as it exists today. I imagine it looked considerable different back in the 1800’s. Unfortunatly we did not get to go down into the tunnel because of OSHA and other company regulations. The large round pipe or duct is the ventilation for the tunnels and drifts. The fresh air is actually pulled into the mines from the other side of the mountain at one of the emergency escapes and pushed out at this point.
Another view of the tunnel entrance and some of the equipment sitting around. None of the crews were working this day (Saturday) but right now they are running two crews employing a total of about 60 men.
(One of the trucks used on the surface with the company name on the bed. There was a lot of equipment sitting around and I only took picts of a few pieces.
One of the larger skips used in the main drifts of the mine. Each bucket load is about a ton of ore or muck rock.
One of the smaller skips, you can see that it is articulated in the center. I like the reminder about maintainence.
The front of the main mill building. the whole place is a combination of old and new structures but all the processing equipment is modern and up to date.
A picture of the older mill building from the upper side, you can see some of the modern crusher and conveyor equipment behind and above the mill.
Another view that better shows the side hill design of the typical ore mill building
At the bottom level of the mill looking back up the hill.
Inside the mill looking up the hill. This building probably dates to the 1920’s-30’s and is all full dimension lumber with large circular daw marks in the wood. The white structure at the foreground of the picture is the OSHA required noise insulated enclosure containing the ball mills. The mills consist of large steel cylinders containing large steel ball bearings (3") that tumble around inside the cylinders crushing up the rock. A very noisy operation even with the enclosure. Where you see the window is the mill operators booth.
A stack of “core samples” taken from various areas inside the mine. These samples are taken in order to try to trace the quartz viens without removing tons of rock unneccessarily.
Believe it or not this is high grade ore waiting to go through the mill for processing. The final processing is not done here on site but the ore concentrates are shipped to Nevada for the final gold extraction.
Hope you enjoyed the tour.
Rick
