John: actually the ties are the same length, but when I glue them down they are never in a straight line and now and then I do use a short tie, if it is close to 3 3/4" length. They are also not perfectly spaced apart. That’s the one thing I hate about sectional track.
Randy: yes that is one continuous rail from the point to the end of the switch. It looks better that way and was easier to do than cutting smaller sections and then having to put Rail Jointers in to connect smaller sections. Yes I am using Switch Crafters code 332 Aluminum rail for all of my track in the Yard area. The Rail on the mainline is code 332 Steel Rail from Delton, which is no longer available. This is for outdoor use.
Ric: I have created a new method of laying track outdoors for both on the ground and on elevated sections that uses 1/4" thick PVC Board (Sintra) to have the ties glued to since I like Hand laying my own track. I don’t dig out a trench and fill it with gravel to float my track on, like most people. I cut a section of Sintra 6 feet long and 4 inches wide, then using PVC cement I glue PVC blocks 1 1/2" x 3/4 x 4" to one side of the Sintra and then I glue 1 1/2" x 1/4" x 6feet strips of sintra to the edges of the 4"wide strip. This forms a ridged frame to glue the ties too and then lay the rail on. Once the track is in place, the entire assembly is put on the ground and then earth and rocks are back filled to the edges to hold the assembly in place on the ground. Curve track is done the same way. When it comes to the elevated sections, I don’t add the PVC blocks or side pieces as they are no necessary. Once the Track is assembled on the 1/4" sintra, the assembly is screwed down to the deck of the elevated areas.
I build my track this way, so I can build large sections in the comfort of my house and then after building a number of sections, I take them outside and install them quickly and easily. After the sections are installed then ground cover and ballast is added.
I have a few photo of a couple of my Turnout assemblies built in this manor using Steel rail. And I don’t use a rail bender to bend my rail either Steel or aluminum, I bend it all by hand. As far as track gauges, Yes I do use a few, mostly ones that I have made from aluminum or Wood. I also use a pair of pliers to hand spike the 1/2" steel spikes.
Dan Stuettgen
Colorado & Rio Grande Southern
http://danshobbies.webstarts.com/index.html
