Hi all,
OK, this links to the PDF with the proposed changes for the scale designations.
OK, this links to the PDF with the proposed changes for the track gauge dimensions. The 1.768" is 44.9mm in metric with a +/- tolerance of .002" (.05mm).
OK, this links to the PDF with the proposed changes for the track gauge dimensions of the Hi-Rail stuff. Apparently for garden railroaders.
Since this is “out for comment” will any of you comment to the NMRA? Or just let the NMRA be the NMRA?
I just marvel at the proposed tolerances and I have a really good chuckle when I compare the proposed with what is actually out there. Did these guys do some sampling? Sure doesn’t look like it to me!
But I have seen plenty of instances of similar “precision tolerances” in NA industry emanating from “offices”, no surprise there!
