Hi all,
Yesterday we got about an inch and a half of new snow, so at dawn I set about opening the mainline. The consist was my Russell snowplow X-67, 2-8-0 #1159 and caboose #01157.
Things went fine as we set out from the garage down to the main track. It was a splendid morning, albeit only 5 degrees. The grade is a steady 2% downhill from here and it was easy going:
Once out on the mainline things began to go awry as we approached the water tank. The snowplow derailed, so I uncoupled the locomotive and began backing up. The locomotive derailed on the south switch at Goodwin and in disgust I left the whole outfit where it sat until things warmed up a bit.
Later in the day I retrieved the equipment. As is often the case with snowplowing, some things got broken. the caboose has a dangling step and the pilot plow on the locomotive split in two. Somewhere I also lost the entire compound air compressor and have yet to find it. Oh well!
Cheers,
Matt
(If I want cold, a beer is GOOD!
