No, this isn’t your agony aunt column.
Took Thomas’s Branch to Long Sault this weekend. Emily was making her usual squeals about R2 curves, audible across the arena; finally, this morning a friend applied some Rail-Zip cleaner/lube to the rails in several spots – and lo, the flange squeals vanished. Unfortunately, Emily is a single (yes, I know Bachmann made her a 2-4-2 rather than a 4-2-2) and after a couple of circuits to distribute the Rail Zip her traction vanished along with the squeals. Quite a sight, those big drivers spinning helplessly – a vivid reminder of Bulleid Pacifics at Exeter Central trying to get under way.
Anyway, I had to use several paper towels to wipe most of the Rail-Zip off the rails and Emily’s driving wheels; she regained traction and her flanges stayed quiet, though the six-wheel coaches did take up the chorus, not quite so noisily.
Anyway, here’s the lady in question, looking quite satisfied with herself.
Actually, I’m probably going to install LGB ball-bearing wheels with power pickups on Annie and plug them into Thomas by way of a DPDT switch in Thomas’s cab. That way, if I feel like it, I can later install battery/RC equipment in Annie for outdoor use, and use the switch to disconnect the track pickups from the motor. Ditto for James’s tender
