The long awaited newest LGB catenary products have arrived here , from the Pizza & Pasta Express . com
The new adjustable base 56302 , and the standard mast 56405 , interlocks tightley in a H pattern connection .
They are just a small tad darker grey than the previous catenary product .
The 56204 part that the catenary wire slides thru , DOES slide thru , tightley , but it does slide , the previous offerings were too tight to slide at all most of the time .
Without going to extremes in measurement , the new mast in the new base , will adjust about a little more than a inch more , out away , from the rail than the previous standard mast , which should provide clearance for about anthing that I will operate here .
I am pleased with the new improved LGB catenary products .
The LGB catenary is the best , outside use , operational catenary available in the world !
