I have the Little Machine Shop Mini Lathe and the Mini Mill. Both better quality then I expected. I have spent a lot of $ on outfitting and supplying the two machines with the necessary extra tool bits and add-ons. I run a 4", 4 jaw chuck most of the time on my lathe. I also have a 5" -three jaw that will fit and turn the bigger stuff. With the DRO package on it, I can really turn to a high degree of precision. I made my die set for the corrugated panels right off the start.
On the mill I have also added a 3-UP DRO units for better precision. The Mill has done all that I have asked of it. Used it to build the frame work for the roof rolling machine.
Plenty of horsepower, Plenty of precision. BTW: you can also turn plastics and wood in/on these machines. Though these pics are all of alum. I have made numerous steel and Cast Iron pieces also. The variable speed lets you set as needed for the cuts you’re making.
Yes, I would recommend them to a friend. BUT, be forewarned, The cost of the add-ons can be substantial. Can you do quality work on the basic machine. Heck yes, You just have to watch the “want” factor versus the “Need” Factor. Do you really need the rotary table for the mill, or just want it because it’s so cool to do the things that it allows you to do (you can cut gears with it). Will it make your modeling life easier, YUP, Think about a ball bearing mount for a turntable, milled into a block of alum. And the spindle bearing to go with it. And the hangers for rollers to go along the inside track. If you can dream it, you can build it.
Edit: BTW the mill also works as a very high precision drill press!
