In preparation for the “Canadian Invasion”, the Fall Ops Session" and advancing the KVRwy to the next level, a lot of time and thought is being put in to new industrial sidings on the KVRwy. I’d like to open for discussion, ideas I’ve realized, thoughts, and generally point the discussion toward what works and what doesn’t. This is model railroad practicality, in a limited space, with limited funds and adapting your railroad to a more operational friendly environment.
an industrial siding can be a single track or multiple tracks.
if possible, an industrial siding should hold more then one railroad car and should be long enough to keep the mainline clear.
an industrial siding can serve more than one industry.
if possible, an industrial siding should be accessed from a passing siding instead of the mainline
if an industrial sidng is short, another siding should be nearby to hold the overflow of cars assigned to that location until there is room.
a teamtrack creates a good industrial siding near a station when there is no specific industry to serve in that area.
trackage for an industrial siding does not need to be maintained as well as the mainline.
industrial trackage should have elevation falling away from the mainline, so railcars do not have a tenedency to roll out and fowl the mainline.
a run around needs to be in the area of an industrial siding to allow the motive power to get on the other end of the car.
if a runaround is not nearby or practical, motive power can get to the other end of a car, by going around a loop of track after uncoupling.
a “to and from” philosophy needs to exist. If you have an industrial siding for cars to be assigned and delivered to, then you need another track to provide these cars for the industry or you need a “fiddle yard” or “staging track” to give another destination.
“Operations” can be achieved with minimal trackage. A simple loop of track and two sidings or a point to point railroad with one end being designated the staging yard and the other end being called the industry.
