Bit more done to the Stirling. Shortened the black braces, they are too long and drilled a hole in them. Used Ozark 1/2" bolt heads around the edges and 3/4" ones on the upright brace. Noticed not much grease on the gears, so if you are running your Emily quite a bit you might want to lube it good.
The front pieces pull out, so that simplifies work some.
