A very good customer has decided to add an AristoCraft Doodle Bug to his roster. Naturally it will have battery R/C and Phoenix sound. Here is how I did it.
First up I drilled holes in the floor for a Phoenix oval speaker. Then I mounted two 7.2 volt 2,500 mah Sub C NiCd packs on the side wall. I used spacers to hold them proud enough so that the two cargo doors could still be opened and closed to gain access to the charge jack and ON-OFF switch etc. Next up was to install a sheet of styrene glued to the speaker magnet and a vertical upright to stabilise it.
The two part RCS BTL-3rA ESC and Spektrum AR500 RX plugged in upside down were stuck to the styrene sheet with silicone roof and gutter sealant. The ON-OFF switch/fuse assembly was glued to the floor at the R/H door. The Phoenix sound was also glued to the floor towards the front of the compartment.
I had to fabricate a small styrene frame to hold the Phoenix programming jack and volume control. This was mounted just inside the L/H door. Screw terminals made wiring up a simple job. The ON-OFF switch is readily accessible.
As are the Phoenix components on the other side.
The most difficult wiring was adding a reversing light at the back of the pass compartment.
All that was then needed was to put the ends back and the roof on. Easier said than done, but practice made perfect after the two or three times I had to do it because I had forgotten to plug in the headlight and then forgot to place the sliding doors in the grooves. Like all AC 2 axle locos this runs superbly. They do get somethings right y’know. Range is not a problem thanks to the 2.4 GHz R/C.
