Thank you OVGRS!
So I did some routine maintainence on my locos today. I noticed that I had a cracked gear in my USA Geep 9.
I remembered seeing a fix for this on OVGRS web site some time ago. Well I tried it and it worked fantastic!!
Only issue I had was the solder joint on one of the posts was a bit heavy and rubbed the fix. A little grinding and all was well. Now if someone can tell me how to get all this fishing line glued to my fingers all would be good!
Thanks again guys!
:wink:
P.S…Anyone know of a gearing fix for the LGB Genesis?
Seems to me you would use the same glue you used to glue it to the gear :D
Psssssst: DavidM, I think he meant, ““get it off his finger””…
Usually I just nod and agree with him, when makes those kinda mistakes… :slight_smile:
David,
You asked - “Anyone know of a gearing fix for the LGB Genesis?”
You must be mistaken. This is an LGB engine, not a Bachmann, USA or Aristo, therefore it is perfect and does not need fixing. I’m sure you must have made a mistake.
Ric Golding said:
David,
Well, he didn’t say a screw fell out!
Andy, I thought he could use another $.02
DavidM :slight_smile:
