this is simply a test
and apparently not a very good one …
Gregory
Under “My Profile” go to “Edit My Profile” and scroll down. There is a block that says “Forum Signature”. Don’t use it. It doesn’t work.
Instead go to the top of the home page and click on “Settings”. Under the LSC banner you will see the words: “My Settings”. Look across that line and at the end you will see “Forum Signature”. Select it. You will get a text block that looks like the Forum reply box. It works just like any forum reply box. Type in whatever you want for a signature including a picture. Hit “Save Changes” at the bottom and you are in business.
The signature script will be applied to all of your posts including previous ones. This applies only to the forums as it does not come up in chat.
Thanks! I think I got it for now …
