freightsheds.largescalecentral.com/users/ddevoto/_forumfiles/Dozer with Archbar 002.jpg
can’t figure out how to add photos to a post. I was told to just add the URL that does not work.
help needed.
Dan
Dan take the spaces out of the name.
or use the my files at the bottom just above the submit button.
onec that opens up load your pictures then you should be able to put them in your clip board
and add it to the post.
hope this helps out.
Geoff is correct about the file name.
You need to change the file name from " Dozer with Archbar 002.jpg" to dozerwitharchbar002.jpg.
Then reload the photo to My Files.
Dan here it is with out the spaces in the name.
(http://freightsheds.largescalecentral.com/users/geogeorge/_forumfiles/DozerwithArchbar20002.jpg)
nice work by the way.
Welcome Dan
