TE onboard Rx range
Ed:
I install my TE reciever in the tender, along with my batteries, My antenna comes out a hole I drilled on the front of the tender, I then drilled 4 more holes on the insides of the Rounded part of the water storage, the antenna is then wove though these holes. For the rest of the antenna, I gooped it along the ridge at the top of the tender, making sure it never touches itself. being my tender is dirty black, the black antenna wire hides quite well. I can get close to 70 feet of range with this system.
Hope this helps!
Running tranis is fun!
