There are two versions of the Tam Valley Depot receiver. The small one is good for HO/On30, and the “Hi-Power” version has a 3-amp continuous rating (5-amp peak) suitable for large scale. I use both. It is a receiver only. You connect battery power to it, and it sends a standard DCC signal out to whatever DCC decoder you choose. The sound, light, and motor functions are dependent on the decoder you connect to it, not the receiver. I’ve paired it with decoders from Zimo, QSI, TCS, Soundtraxx, Massoth, and others. (Joe, Woodland Railway #220 uses one to drive the QSI decoder.) They’re similar to the Airwire Convertr series of receivers, but there are some key differences to keep in mind:
The Tam Valley Depot is a passive device. There is no programming involved to get it working. Battery in, DCC out. It’s that simple. It only works on Airwire channel 16. You cannot change this. If you run in an environment where you’re the only operator, then this won’t be an issue. If you run in a club environment where others are using Airwire, you may run into issues if someone else is operating on channel 16 and cannot change their setting. This isn’t necessarily as big of an issue as it may seem, as Airwire has a limited range to begin with, and with the T-5000 throttle, you can pull the transmitter power way back so its range is maybe 10’ at the most, allowing you to operate with other Airwire operators on the same frequency. That’s largely why Airwire put that feature on the T-5000. Note that you cannot adjust the transmitter power on the T-9000 or new T-1300 OPS throttles. (Joe, for reference, all of the locos on the Woodland Railway run on different Airwire frequencies, which is how we have multiple operators all using Airwire. The NW-2 uses a Tam Valley Depot receiver, which is why it’s set to channel 16.) Even if you have multiple locos with receivers set to channel 16, so long as the DCC address of each of the locos is different, you will not be able to actually control the other’s locomotive. The worst that happens with two Airwire transmitters set to the same frequency overlapping each other is that no signals get through.
The “passive” nature of the TVD receiver makes it a good candidate for building a battery power car if you were to want to save some money and use one car to run different locos. You’d install the DCC decoder in each individual loco (or perhaps the loco has one already installed, such as LGB or MTH), and you’d put the battery and TVD receiver in the power car behind, needing only to run two wires forward to the loco itself. (You’d need to disconnect the rail inputs and connect the DCC decoder to the input of the battery car instead. (Toggle switch to select either one?)
In contrast, the Airwire Convertr boards must be programmed to both frequency and DCC address. This means the receiver must be paired permanently with the decoder to which it’s attached, since they must be operating on the same DCC address. You can change the frequency of the Airwire board (CV200), but you need to make sure that there’s not anything on the decoder that uses that same CV number, lest you change the value for that at the same time. (If there is something controlled by CV200 on whatever decoder you are using, you would have to install a disconnect switch to allow you to program the Convertr without adversely affecting the decoder.) The key advantage of the 6-amp Convertr is that it’s rated at 6 amps continuous (55 amps peak), so it’s a much more robust board for controlling large or heavy-hauling locomotives. It’s also more expensive.
