In fact, it seems like I have sort of a solution - with fewer steps than my initial estimate.
I really wish we had some kind of app that you could use to set up this simulation. I’m not really sure my steps work, as I changed my approach several times. Dead ends, anyone?
Anyway, good luck trying to follow this; I’m not sure I can even though I wrote it.
I tried to use alternate between backup and forward as appropriate, but I might have messed it up a few times.
I’m betting there’s a much more clever set of moves.
At any rate…my attempt:
- Pull the train forward to clear SW2.
- Backup and leave the caboose on track MW.
- Pull forward. Clear SW2.
- Back up and clear SW1 with 3,2,1.
- Backup on MW. Couple to 4,5,C.
- Pull forward, clear SW2.
- Backup, dropping 4. (Now 3,2,1,4 on track to Jackpine).
- Pull forward on Wye “L”, coupling to 9.
- Backup, clearing SW1.
- Pull forward, leaving 9 on T1.
- Backup to clear SW1.
- Forward to FS.
- Backup on Wye “R”, clearing SW4.
- Forward on WH, coupling to 7.
- Backup clearing SW4.
- Forward, dropping 7 on FS.
- Uncouple. Backup on Wye “R” to Wye “T”.
- Forward to clear SW1.
- Backup to couple with 7 on FS.
- Backup to drop 7 on T1, coupling to 9 already on T1.
- Backup on Wye “L” to FS.
- Forward on Wye “R” to Wye “T”.
- Backup, pushing 7 & 9 to clear SW1.
Now, on the track to Jackpine, I have 3,2,1,4,7,9.
MW: 5,C
WH: 6
I’ve done the pickups. Now it’s time to do the transfers.
We’ll start with 6.
27. Forward on Wye “L” to FS.
28. Backup on Wye “R” to clear SW4.
29. Forward to couple with 6.
30. Backup to clear SW4.
31. Forward to drop 6 in FS.
32. Backup to Wye “T”.
33. Forward to clear SW1.
34. Backup on Wye “L” to pick up 6 at FS.
35. Forward on Wye “L” to clear SW1.
36. Backup on Track 1, clearing SW2 leaving 6 on Track #1.
I’d like to get 5 now, but I have to be able to move it to the warehouse, and I’m on the left side of 6. Crud. If I leave 6 here, I don’t see how I can move 5 to WH. Well, 6 has to end up at the quarry, let’s put 6 on the line to the quarry. But, first, I’m going to grab that caboose off of MW and stick it on to the end of 9 on Track #1 to Jackpine.
37. Forward on MW, coupling to the caboose.
38. Backup on MW to clear SW2.
39. Forward to clear SW1.
Now, on the track to Jackpine, I have 3,2,1,4,7,9,C.
MW: 5.
WH: 6.
Time to get 6 and move it towards the quary.
40. Backup on Track #1 to Wye “T”
41. Forward on WH to get 6.
42. Backup on WH clearing SW4.
43. Forward on Wye “R” to drop 6 at FS.
44. Backup on Wye “R” to Wye “T”
45. Forward on Track #1 to clear SW1.
46. Backup on Wye “L” to couple to 6 at FS.
47. Forward on Wye “L” to clear SW1.
48. Backup on Track #1, leaving 6 on Track #1.
Now get on the other side of 6 and push…
49. Forward on Track #1, clearing SW1.
50. Backup on Wye “L” to FS.
51. Forward on Wye “R” to Wye “T”.
52. Backup on Track #1, pushing 6 to clear SW1.
Now, on the track to Jackpine, I have 3,2,1,4,7,9,C,6.
MW: 5.
WH: Empty.
Finally we can think about moving 5 over to the warehouse.
- Forward on Track #1 clearing SW2.
- Backup on MW, coupling with 5.
- Forward on MW, clearing SW2.
- Uncouple 5, leave it on Track #1. Forward to Wye “T”.
- Backup Wye “R” to FS.
- Forward on Wye “L” clearing SW1.
- Backup on Track 1, coupling with 5.
- Forward on Track #1, clearing SW1.
- Backup on Wye “L”, leaving 5 at FS.
- Forward on Wye “L”, clearing SW1.
- Backup on Track #1 to Wye “T”.
- Forward on Wye “R” to couple with 5 at FS.
- Backup on Wye “R” clearing SW4.
- Forward on WH, leaving 5 at the Warehouse.
Whew. Now, lets put 6 in quarry, moving 8 out first, of course.
- Backup on WH to Wye “T”.
- Forward on Track #1, pushing 3,2,1,4,7,9,6, past SW Q.
- Uncouple, Backup on Track #1, clearing SW Q.
- Forward coupling to 8.
- Backup, clearing SW Q.
- Forward coupling with train (3,2,1,4,7,9,C,6)
- Uncouple at 6. (Now have 6,8) Backup clearing SW Q.
- Forward, dropping 6 at quarry.
- Backup, pulling 8 to clear SW2 on Track #1.
- Forward, dropping 8 at Monument works.
Right now:
Quarry: 6
MW: 8
Warehouse: 5.
Train to Jackpine: 3,2,1,4,7,9,C
Finally. Done with the pickups and transfers.
Oh yeah, we still have some deliveries.
I’m going to split the train.
77. Backup on MW to clear SW2.
78. Forward on Track #1 to couple to train: (3,2,1,4,7,9,C)
79. Backup on Wye “L”. Split train between 1 and 4, leaving 3,2,1 left of SW1. 4,7,9,C continues to FS. Uncouple from train.
80. Forward on Wye “R” to Wye “T”.
81. Backup on Track #1 to couple with 3,2,1.
82. Forward with 3,2,1 clearing SW1. Uncouple and end up in Wye “T”.
83. Backup on Wye “R” to FS.
84. Forward on Wye “L”, pushing 4,7,9,C to clear SW1.
Right now:
Quarry: 6
MW: 8
Warehouse: 5.
Track #1: 3,2,1
Train to Jackpine: 4,7,9,C
Engine around SW1.
- Backup on Track #1 to couple with 3,2,1
- Forward on Track #1 clearing SW1.
- Backup on Wye “L”, leaving 1 at FS.
- Forward on Wye “L”, leaving 3,2 on Wye “L”, clearing SW1.
- Forward on Wye “R” to couple with 1 at FS.
- Forward on WH, leaving 1 at Warehouse.
- Backup on WH, clearing SW4.
- Forward on Wye “R” to FS.
- Backup on Wye “L”, pushing 3,2 clearing SW1.
- Forward on Track 1 clearing SW1.
- Uncouple 3 from 2. Leaving 2 on Track 1, backup on Track 1, clearing SW1.
- Forward on Wye “L”, leaving 3 at FS.
- Backup on Wye “L”, clearing SW1.
100.Forward on Track #1, coupling with 2.
101.Backup on Track #1, clearing SW1.
l02.Forward on Wye “L”, stop and uncouple 2.
103.Backup on Wye “L”, clearing SW1.
104.Forward on Track #1, ending at Wye “T”.
105.Backup on Wye “R”, coupling with 3 at FS.
106.Forward on Wye “R”, clearing SW4.
107.Backup on WH, leaving 3 at Woodenware Works, ending at Wye “T”
Right now:
Quarry: 6
Monument Works: 8
Warehouse: 1.
Cannery: empty
Woodenware Works: 3
Track #1: 2
Engine around Wye “T”.
- Backukp on Track #1, pushing 2 to couple with 4,7,9,C.
- Forward on Track #1, clearing SW 1; uncouple from train, and continue to Wye “T”. (Track #1: 4,7,9,C,2)
- Backup on Wye “R” to FS.
- Backup on Track #1 coupling with train: 4,7,9,C,2
- Backup on Wye “L”, dropping 2 at FS.
- Forward to Jackpine.
