I have some 10 light strands of street lamps that are made to plug into 120 volt house wiring. Each bulb is rated at 12 volts and they’re currently wired in series.
I have taken the strands apart to get the spacing I want and I’m going to power them with 24 volts DC. Should I wire the lamps as two in series off of a parallel feed or should I run three in series connected to my parallel feed to keep from over powering the bulbs?
I hope that clear.
I caught a glimpse of a couple of rays shining through just last week!
